Tuning Basics Book?
Even though the tuning is similiar, it's going to be based on which tuner you decide on. There are "sticky's" on this forum that are specific for the most commonly used tuners. There you will find very specific information and those pages also have inputs from some of the best tuners around.
There are a few good books. But see how much of this you can digest...
http://www.megamanual.com/begintuning.htm
Here is the deal. In todays auto world, all cars are tuned with a speed density system using a MAF. Mass AirFlow. A MAF actually weighs how much air enters the intake track.
Harley bikes use a speed density system, but does NOT use a MAF. Instead, our system uses a look up table to decide how much air is being used. This table is the VE table. Speed density is called such because it uses a MAP (Manifold Absolute Pressure) sensor to determine the load upon the engine. The higher the MAP the higher the load, the different VE table it looks towards. Three vectors are used here. Throttle position, rpm, and MAP. Autos still use these same three positions, but the VE look up table is a hybrid that uses not only VEs, but actual weight of the incoming air charge.
So, we use Speed density without a MAF. Also good reading would be to get a very basic understanding of older systems. Alpha N is an older tuning system. Alpha N is to two vector system that uses Throttle position and RPM. Alpha N cannot truly tell the actual load being placed upon the engine.
TMax is an Alpha N system, for example.
With the above in mind look for simple How To Tuning Basics books for cars, and remember our bikes are a bit different. Tuning is tuning up to a point, so NO reading, on your part will be wasted. Our bikes also have ION sensing, but save THAT for later. ION sensing is a safety system that folks use to help with timing, but it is NOT the proper tool to use for timing.
I have the name of a good book right on the tip of my tongue... damn alzheimers!
Here is another decent website to peruse for cars. http://www.enginebasics.com/EFI%20Tuning.html
I am googling around trying to find a book or two I have read in the past, for you. Might not have luck at that today.
Old EFILive discussion on MAF-vs- straight VE tables. http://forum.efilive.com/archive/index.php/t-1773.html
Screw Alzheimers... Here is the book I would suggest you read to gain a start....
athompson
27
07-24-2006 12:38 AM
