Need help with rear turn signal
Where do I start. I have a 2010 street glide. I tore the bike apart for powdercoat, 23 front wheel and bars. I cut the wires to coat the rear light assembly. When I put it back together I thought I would go with led lights. All the lights work great except the left rear. At first nothing would work and figured out the LED was bad. So I tried the other light and only the running light works. No brake light or blinker. So I read a bunch of forums and checked the connections. Once I plugged the light back in, the brake light stays on. I have no clue what to check next. Please help. Thanks.
