Electronic Control Module
Electronic Ignition Module '83-'93 Evo Type frame-'04 engine
What EIM fits the 12 pin rectangular connector on the main wiring harness, Evo type?? (Male)
Main wiring harness came from V-Twin mfg. '83 - '93 Evo type. (female)
Need part # or any info would be appreciated.
Evos of that era only have an ignition module. An ECM is normally used to describe a fuel injection related module. V-twin offer several Electronic Ignition module options, so contact them. You may also need a wiring extension to match the module to your harness, but they should be able to sort that as well.
Jimpool
02-16-2013 05:52 PM
stuboy-2001
12-29-2012 03:03 PM
