pc v
it's a good device for it's intended purpose and audience
Pros
Less expensive than other full blown tuning devices
Allows adjustments of AFR and few other tables
No steep learning curve
quick to install
lots of maps available from DJ and FM if you purchase from FM
doesn't marry itself to the bike
Cons
No where near the flexibility of a full blown tuning device
Can't adjust important areas such as EGR and Timing that are affected by pipe and A/C changes
piggy back device must stay plugged into the ECM at all times
I'm sure others will chime in with things I haven't mentioned.
Pros
quick to install
Cons
Pros
quick to install
Cons
Pros
quick to install
Cons
fuelmoto
60
02-25-2011 10:57 AM
sporty
06-13-2010 11:39 AM
