Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Quick question...my AUX lights don't turn on with the ignition switch, is this normal? Also, with the ignition switch on, and a multimeter across the leads for the aux lights, I have 12V showing...plug the lights in, no workie...touch the light connectors to a spare battery I have lying around, boom...workie! WHAT THE HELL AM I MISSING!?
I thought that was the case too, but if it was in fact the case, why would my multimeter read good voltage across the hot wire AND the ground wire in the light bucket? If the ground was bad I. The light bucket, wouldnt I read an open, or zero volts?
Genius...for some reason the ground wire riveted to the light bucket will give me a good voltage reading, but not good enough to light the light! Now I gotta figure out how to ground them! Ideas?
