PCIII accell pump
RE: PCIII accell pump
You need to run the utility from Power Commander nad follow the instructions. All information on it is at http://www.powercommander.com/accelpump.shtml
Nv,
are you maybe referring to the start fuel function? This is for more agressive builds.
The accell pump is fine for stock engines- it just gives a little extra throttle response to suit rider preferences.
We have been set it up on 6-7 07s in the last few weeks and all are running fine.
cheers
Mick
cheers
Mick
I had bad hesitation if I snapped the throttle from idle... I enabled and set the accel pump feature and it eliminated 99% if the problem. When the weather turns a little warmer I am gonna fiddle with the settings to see if I can get that other 1%.
for me, enabling the accel pump feature on my 2006 roadglide was a good thing.
wingnut79
09-07-2006 02:26 AM
Anthony8858
10-26-2005 05:29 PM
