Thundermax ECM Thread
#481
Ran into some starting/running issues on my bike with T-max installed…need some help diagnosing;
Bike won’t start or stay running with Thundermax installed. I can take it off and put the factory ECM back in with the piggyback Dynojet Power Commander and it starts up and runs great.
Been through all the settings on the Thundermax, re-installed the correct map, re-initialized the system before trying to start, verified all the sensors and relays are good as well as the O2 sensors.
What gives with the Thundermax!?!
#482
#483
Yes having O2 reversed will...
yes having O2 sensors reversed will cause the ECM to not adjust properly. Also with my 07 sportster i had to set the target AFR rather rich until the computer could build a map. Double check your o2 sensor wire installation and go from there. After that send a run to T Max. They are pretty good on helping.
#484
I’ll double check the O2 wires but 99.9% sure they’re correct.
Can’t get it to start and/or run long enough to document a run…between the long cranks and backfires (both through the intake and the exhaust) it sounds like it’s being starved for fuel. But swap in the stock ECM and a Power Commander and it runs like a champ.
#485
Yep 07 Bagger…new to me T-max, was never installed on the original bike it was programmed for. I re-registered it and loaded the appropriate map as per their instructions.
Send the info to Tmax. They'll help if they can.. Even if you are not the original purchaser. One thing possibility would be a weak crank sensor. The HD unit is sensitive enough to pick up the signal but the Tmax is not..
#486
Crank sensor
TPS sensor
IAC valve/sensor
Battery
Stator and rotor
Starter relay(s)
Cleaned injectors
Fuel filter
Fuel pump
New fuel lines in tank
Fuel Regulator
Fuel regulator housing (Trask)
Fuel check valve and line to injectors
Have a new head temp sensor coming as well
#487
Heres also a list of what I’ve replaced in my quest to get this to work;
Crank sensor
TPS sensor
IAC valve/sensor
Battery
Stator and rotor
Starter relay(s)
Cleaned injectors
Fuel filter
Fuel pump
Fuel Regulator
Crank sensor
TPS sensor
IAC valve/sensor
Battery
Stator and rotor
Starter relay(s)
Cleaned injectors
Fuel filter
Fuel pump
Fuel Regulator
After re-installing a bit “simpler” map for my setup and re-initializing everything the bike started up great and runs very strong. Guessing my hunch was right so hopefully fingers crossed it continues to run great.
Max Headflow (07-31-2024)
