Thundermax ECM Thread
Old 03-05-2024, 10:55 AM
Jay Guild's Avatar
Jay Guild
Jay Guild is offline
You can get the USB cable to interface the Thundermax but I think all it will tell you is "no combustion on front cylinder" There isn't a sensor for gas flow that I'm aware.
  #472
Old 03-05-2024, 02:41 PM
cobra23's Avatar
cobra23
cobra23 is offline
I would contact Thundermax tech support. They are pretty responsive.
  #473
Old 03-05-2024, 06:38 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is online now
Received 6,008 Likes on 4,061 Posts
Tmax really doesn't have any way to detect "combustion". It's a Delphi thing.
  #474
Old 03-06-2024, 11:48 AM
matt_eglide's Avatar
matt_eglide
matt_eglide is offline
Need some help/expertise...just installed a new-to-me 309-460 unit on my 07 Electra Glide. Everything on the unit was cleared out and I started with a clean and accurate base map for my bike/setup. I set all of the AFR's for my liking as well as all of the basic settings and all loaded successfully. I initialized the module a couple times with the ignition as well as allowed it to come up to temperature idling without touching the throttle as per the installation instrucitons.
Took the bike out for a 50 mile ride and it did amazing, came home and re-wrote the module to load in the learned fuel offsets from the first autotune session and all looked great.
On the second ride, the bike shut off a couple times when idling after a few seconds of coming to a stop. Didn't matter if I came to a stop in neutral or first gear, it seemed to want to idle funny or make an adjustment in the idle speed and then it would shut off. It would start back up totally normal and then idle fine after that.
Thoughts??
  #475
Old 03-06-2024, 12:48 PM
nevil's Avatar
nevil
nevil is offline
Received 1,036 Likes on 774 Posts
Thoughts??
Try cleaning the IAC.
  #476
Old 03-06-2024, 01:32 PM
Max Headflow
Reload the original map you started with. Do the throttle learn again. Don't bother with automapping until you have 500 to 1000 miles on it.. Whenever you start the bike make sure the throttle is closed. If you like to have your hand on the throttle when pressing the start button make sure that you are not rolling on the throttle slightly. It will screw stuff up..
  #477
Old 03-06-2024, 04:06 PM
matt_eglide
Installed a new intake manifold with a new/OEM IAC motor/valve but I can always clean it out easy enough.
I’ll go back in a re-install the MAP and do the sensor re-learn again and see how she rides then.
Thanks for the advice!
  #478
Old 06-19-2024, 07:50 PM
davekp's Avatar
davekp
davekp is offline
What if you are running a T-max and reinstall the OEM ecu. Could the dealers service department detect this?
  #479
Old 06-20-2024, 03:19 PM
Rider's Shipmate's Avatar
Rider's Shipmate
Rider's Shipmate is offline
Stage I
Default Thunder Max / Stock ECM Swap
It is recommended by Thunder Heart to stow your ECM on your bike in the event you have to go into the dealership for repairs.
The Thunder Max ECM is a "Black Box" component. As such, it is undetectable if not installed.
However, if the tech notices the installation of 18mm O2 sensors, well then, "Lucy U got som splain'n to do!"
This is the fault with the instructional advise. The stock ECM uses 12mm O2 sensors which installs into your bike's internal wireing. 12mm O2 sensors are removed during installation and their connectors are plugged (dead ended). The stock ECM cannot use 18mm O2 sensors. Therefore reinstalling the stock ECM on the fly would leave you open to the question of, "Where are your 12mm O2 sensors?"
The Harley diagnostics would recognize the absence of the 12mm O2 sensors.
  #480
Old 06-20-2024, 05:23 PM
Harley_ish's Avatar
Harley_ish
Harley_ish is offline
Harley also used factory installed 18mm O2s
Quick Reply: Thundermax ECM Thread
