Thundermax ECM Thread
#461
#462
It doesn't show what the actual timing is? Only the degree of change? That is f'n annoying. I want to know what it is. Like 29.4 °. NOT -2.7 ° meaning retarded 2.7 ° from some predetermined number it deems top secret or some dumb ****.
I've seen maps posted here like that. +2°, -3° etc. Is there anywhere it shows what the actual timing is?
#463
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
#464
I've got the same issue on my '22 FXLRS after installing a Thundermax.
#466
Thanks for this. I'll relay it to the shop that installed my tuner. Did you load the update yourself? I haven't messed around with the software myself yet.
#467
#468
#469
Ok thundermax gurus, I’m a novice and wondering if I could get some help.
I have an 2005 road king with a thundermax ecm. I bought the bike used and don’t have the original ecm or cables to hook up to the thundermax. My problem is my front cylinder isn’t firing. I’ve got good compression, spark but no fuel. Noid light shows the wiring is good up to the injector. If I get a cable, could I run diagnostics to see if the injector is opening?
basically, I don’t know if the ecm is bad or the injector. And I’m tired of throwing parts at it.
#470
The following 2 users liked this post by porkster:
Jay Guild (03-05-2024),
Max Headflow (02-24-2024)
