Thundermax ECM Thread
#431
Hey guys,
Have a ping issue at throttle roll on/full throttle and been pulling timing out map at 2500 to 3500 RPM were i'm getting ping & just about got it out but still have the slightest ping still there and drives me nuts! LOL
I have 5 degrees pulled on full throttle(Ping solved) 3 degrees on belly (Slightest still there) of map 8 degrees total on RPM above and was wondering would it be ok to go one more degree to get last of ping?
I can't fine any were to the max that can be pulled.
Any info would be appreciate thx.
Engine is Screamin' Eagle Twin Cam Tire Shredder Kit - 103CI to 110C
#432
Hey guys,
Stage5 (09-23-2021)
#434
The following 2 users liked this post by Max Headflow:
Harley1004 (08-08-2022),
Jay Guild (09-24-2021)
#435
#436
Yes, the Thundermax will continue to tune your AFRs. I will NOT auto tune your timing. This is why it is so crucial to load a base map that closely matches your build. It doesn't have to be a 113 map. A 110 map with a similar cam, TB, exhaust will work MUCH better than a poor matching 113 map.
Most Thundermax maps use Red Shift, SE, S&S or Andrews cams. Look at your cam timing events and find a 110 Map that best matches your cam. You can either load that map or copy and paste the timing tables from that map to your current map. I recommend the latter.
#438
#439
#440
Code 2101 TAC Actuation code
Hello all have a 2020 road king special with a stage 3 122 with woods 22xe cam s&s 55mm ported polished manifold with 5.5 injectors been trying to get my bike not having a miss runs good
In TAC idle position screen alarm limit settings was set at low 0 high 0 not sure what this means maybe perfect 5vdc? At this setting have my miss if change to 10 low 20 high its better am i fixing a problem or masking a problem? How far can you adjust ? What do the gauge value limits do? Mine are. current value 85.00 gauge min value 0 gauge max value 200 Operational ranges 5 yellow caution stops red warning 90 thanks for any advise will take screen shots tomorrow and post
history on the bike ran great as a stage 1 after stage 3 install been chasing gremlins this is the last one i hope
