05' FLHRCI, PC III and Me
For all you tekies, my bike is as described in my signature line and the problem is my check engine light comes on when I get crack the throttle hard at road speeds in almost any gear, but mainly 5th and OD(6th). Yes, it shows the "No Combustion" code, P1536.
Is it a possibility that the ignition curve in my PCIII map is set incorrectly?
I have played with leaning out the cruising RPM range, but this has had no affect at all. That leaves me to believe my timing is incorrect.
I bought the bike used and have checked almost everything that has been suspect, from the fuel line rub in the tank to voltages.
Any help would be greatly appreciated!
AdrianVall
08-11-2008 07:15 AM
