Daymaker Headlight
Daymaker Headlight
Anybody have an idea or solution how you can wire a daymaker so the low beam stays on while its set on high? I was thinkin if you could run a jumper wire from the high beam wire to the low beam wire with a (diode)? Diode would be used of course,so voltage would not travel to high beam when set on low!Figured since LED's draw significantly less amps,there shouldn't be a problem.Any thoughts or suggestion will be appreciated!
