Carburetor problem 1998 Evo
The problem could be that the idle circuit is blocked, or there is an intake leak.
Kill two birds with one stone: remove the carb, disassemble and clean it, and replace the intake seals between the manifold and the heads.
Watch for the tiny washer and o ring when you remove the low speed adjusting screw.
Also inspect the seal where the carb mounts into the manifold.
