98 springer losing a cylinder?
Hi guys, I put a dyna s ignition in about a year ago and I keep having coil problems.... I burned two up so far where it just runs on one cylinder.... So I put a new coil in and it runs good for a couple weeks..... There is no Harley wiring left, the only wiring left is tail light and headlight coil and ignition and on off and the coil is a 5 ohm coil... But do you think that I should be running a dyna coil with the dyna ignition or could it be another problem?
johnk
08-27-2010 11:23 AM
