New 2013 Road King - Need Tuner Advice
Just picked up a new 2013 Road King.
First of all, I'm not a speed demon, and this bike will be used mostly for touring. I do virtually all of my own work.
The dealer tells me that I need a new head pipe and remove the cat and add open mufflers and a new air cleaner and a SERT and a dyno tune.
Holy S@*T how much does that all cost ?
I'm not into LOUD, but a nice rumble would be good. (We also have a 2008 Fat Boy with V&H pipes and quiet baffles, and a Cobra CVT for fuel management)
I suppose that it would be too much to ask to simply be able to put on a set of slightly louder slip-on mufflers, and leave it at that?
Seriously, what do I really need?
Thanks, in advance
Thanks, in advance
Check Fuel Moto website also check this tread for good info; https://www.hdforums.com/forum/touri...fuel-moto.html
I don't know how much an exhaust system for your sled will cost. But the SEPRT / Dyno will cost you about $800. And it is worth every penney.
Thanks, in advance
Thanks, in advance
If the heat on your right leg bothers you, then change the headpipe to get rid of the cat ($300-$500 depending on which way you go).
If you decide to change the A/C too you'll need a tuner. The A/C isn't too expensive ($100-$150), but a good tuner will be (+ $400-$500).
Maybe start with the mufflers and then decide if you need to go further.
I also like Fuel Moto. They can supply whatever you need at reasonable prices with outstanding Tech. support.
You could just do the mufflers...shouldn't need a tuner for just mufflers and cost will be reasonable.
Maybe I'll get a hole saw after the factory mufflers. Hahahahahahahahahaha
This 2013 has more power and is smoother than our 2005 Road King, so we're relatively happy with it, right out of the box.
Received 5,294 Likes
