Harley garage door opener prob?
I just installed the harley garage door opener on my 02 FLHTC. The problem is i also have a RM lighting HID and when i have the headlight pluged in the opener wont work. Unplug the head light and the opener works. Anyone have any ideas why this might happen? When turning on the high beam the HID stays on, could it be that with both lights on they drain the electical system enough that the transmitter wont function?
Any ideas would be helpfull
Thanks
AJ
Thanks
AJ
RE: Harley garage door opener prob?
thanks for the help Geek, I rechecked all the conections everything looks good and to the best of my knowlage (stab light)tested good. I also put a trasmitter on my wifes FLHX, works great. since i had it apart i put her fairing and head light on my classic and everthing worked great opener and all. So I'm at a loss, has to be something with that HID. but what?????
Thanks again
AJ
Thanks again
AJ
ORIGINAL: VrodAJ
After doing some more checking i found that the low beam stays hot all the time with the HID pluged in. I think the transmitter low has to shut off and turn back on for it to work. I have tried rewiring it and couple different ways, even tried wiring it to the blinkers. The next step would be wire a rocker switch on the dash.
Thanks for the input
AJ
AJ
