Problems programming ECM using race tuner.
I have a 2006 FXDI35 that has been tuned with a screaming eagle race tuner. Recently, I have needed to modify the warmup enrichment table to eliminate a hesitation,stumble, stall problem when cold. Well, the damn tuner stops at 20% and displays " ECM Access denied, Quitting". What's up with that? This tuner is already matched to the bike. The original calibrations were performed by Santa Fe Harley in 2007 and the tuner hasn't been used since. I've changed the serial adapter, com port and reloaded software to version 462 from 452. I've tried different tuner files but it always fails at 20%. I'm not willing to shell out another $500 for a tuner. Any help?
Originally Posted by pigfarmer420
did you ever figure this out im having the same issue
