New version of sert
RE: New version of sert
I'm waiting for the newer version also, prefix G. I'd also like to know if anyone know's what the revision are. Also, as far as your question, I understand that the only canned map's which are included in the SERT software is for HD parts only. Someone correct me if I'm wrong, thx, Putt
You will NOT find a map that is pre-designed for the SERT with anything other than HD /SE components.....
What you have to do is use a map that MOST CLOSELY RESEMBLES your current configuration.....
SERT maps are engineered with HD/SE components ONLY....
As far as the changes to the current version (rev J), the HDI maps were implimented, Touring maps (6 of them) were made more effecient, and ACR (Automatic Compression Release) maps replaced the original 110/113 maps...
Thank's Bob for your imformative post.
I'm waiting for my SERT now so I havn't had a chance to take a look at it yet but I'm going with Rinehart True Duel's and since the SE line has nothing but a two into one or slip on's for a Dresser, will I be able to find a programmed map close enough? If so, what would you suggest? Thx in advance, Putt
Wide06
10-14-2007 07:55 AM
