Road King died
Road King died
Hello everyone, I have a 2005 RKC runs great until today. Pulling into a gas station the bike shut off by itself in mid turn and lost all battery power. Checked the normal fuses etc. everything looked fine. Waited a few minutes turned the switch on, no power, lights absolutely nothing. Got a ride home picked a trailer hauled the bike home. As soon as it was off the trailer I hit the switch everything worked. Started up and ran as usual. Took the seat off and side covers pulled and pushed all the wires/connections I could get at, checked the battery connections, fuses and everything looked ok. If there was a short I would think I should have at least blown a fuse. Gonna think about it for a few and pull the dash off and check the ignition switch and check the wires under the tank. Got me puzzled right now.
I as well had the same issue with a 97' FLHTCU. I called the local stealership here in Alabama and found there was a recall on the ignition switch for that very reason. Mine had died in the middle of a construction zone on I65 and my wife panicked when all we could see was those orange safety barrels coming at us. Anyway, got the recall taken care of and it never happened again. By the way, the original owner knew nothing of the recall and I had it done 6 years later, so call and check on the recall notices for your bike(s).
Just my $.02 worth.
Safe riding!
Just my $.02 worth.
Safe riding!
IIRC, there is a circuit breaker(CB) on an 05? I could be wrong about what year they stopped using them.
If the bike DOES have a CB, swap that out for a Maxi Fuse. The switches DO have a recall. Sounds like a CB to me... cools off and works again.
The 97 has a CB for sure. Trash that and change to a Maxi Fuse... like a 40-50 amp fuse.
Tris S
General Topics/Tech Tips
05-15-2019 11:06 AM
stmcmann
08-29-2018 07:57 AM
M&P340
04-29-2012 05:55 PM
