Lights added to FLHTC continued
Things you should know if you decide to add HD light kit 67932-11. It only comes with 2 antennae mounts like the Ultra's have. I followed another poster's suggestion of using a vacuum cap over the unused antennae post. Then you have the problem of all the additional wires and connections in the tour-pak. I chose to go with HD's hard insert to hide and protect them. The king tour-pak hard insert only comes made for the Ultra with the factory light kit. Meaning you have the large back corner pockets. This cuts down on the available packing space in the Classics tour-pak, but you need those pockets to successfully cover the rather large wiring connections this light kit requires.
Here is the pic again of the vacuum cap over the antennae post:
