New saddlebag light wiring
So I purchased some new saddlebags for my wifes bike, with lights. I wired them by splicing into the wires for the tail/brake lights. They all work fine with One bulb in one saddlebag as soon as i put in the second bulb, when I turn the bike on and press the brake the brake light comes on and goes off and doesnt work again until i turn the bike off then back on and the light does the same thing. With one saddlebag bulb in, the lights work fine, as soon as I put in the second saddlebag bulb it does as decribed above. HELP! Any thoughts?
Its a 2013 deluxe. I did post it un the electrical forum too. They are just 3 wire two filament sockets. I spliced into the tail light wire for the tail light function and the brake light wire for the brake light function. I spliced in right before the plug in the harness under the seat. All fuses are good, like I said, it works on initial turn on each time. It seems like the brake light relay isn't liking it but Im not exactly sure how the relay works or what I can do to make it work. It seems like the relay works n initial turn on and then when I push the brake it stops working, like a contact in the relay fails or something. I dont know if I need to add a resistor or something crazy in the wires or what. Like I said, I dont know how the relay works or if it is even the relay. Like i said it works fine with one bulb but not both, like the second bulb is drawing too much current or something and messing with the relay?
Damien Bessent
09-20-2022 03:36 PM
dan_sandyrichards@sbcglobal.net
Electrical/Lighting/Alarm
11-02-2017 03:27 PM
