Need PC3 dynoed Map for 07 Ultra with Bassani true duals
The following are the specs from the "notes" in the dynojet downloaded map. The bike has all of these except the intake is a Ness big sucker. I would like to see any other maps with this configuration. The bike runs pretty well, No backfiring etc but the rear cyl still seems way too hot and it stumbles off the line. I'm looking into other causes for the stumble. The stock map has zero's across the board for 1000RPM and lower on both fuel tables. Was wondering if anyone's map is different.
2007 Harley Davidson Touring Model *Advanced Map*
Bassani Power Curve True Dual headers
Bassani Reverse Mega short core muflers
Screamin' Eagle Air filter
Stock ECM
Dynojet O2 sensor eliminators installed
Rev Xtend enabled
Stock ECM
Rev Xtend enabled
