Help me tune with TTS
My build is a 2007 FLHX. I started with a 107 kit with woods tw-777 cams, screaming eagle air filter, and samson 2 into 1 exhaust. After my first attempt I found that I had a leaking intake valve. That has been replaced with new heads flowed, larger valves, and stronger springs. My compression test now shows 190 front and rear.
I throw my laptop in the saddle bag and set up an ad-hoc network with an ipod touch using Jumi to remotely view the laptop screen. For the vtune maps PE is set to 10000, AFR table is maxed, and adaptive knock retard table is set to zero.
I started with DPG176-03-A0 and did a camtune: https://app.box.com/s/762tazodtugm9z843gj7 choose 2 for open and 3 for close.
First run https://app.box.com/s/lzdhf0jewx2ezludjo5z with https://app.box.com/s/xdfvnxiqpttbegv8rp62
Set front and rear bias to 700, ran vtune, lowered IAC crank to run (I was getting kickback and grinding from the starter)
Second run https://app.box.com/s/6tejn8vdd9nh1at9ce1q with https://app.box.com/s/9z9801bwhiqe4uvsbd9f
ran vtune
Third run https://app.box.com/s/qprm7bpj0g3a6gq11flp with https://app.box.com/s/g6hc4fgjd9ocfz00ch1j
ran vtune manually adjusted VEs up 25% from 2250 to 3500 trying to richen the mixture because I couldn't get those cells to fill
Fourth run https://app.box.com/s/6406zbxmap63uwcxsi9w with https://app.box.com/s/ffuod26pbkl284n5h6ip
ran vtune imported spark table from a previous tune (I swear this damn bike loves a lot of advance for some reason please don't yell at me Wiz) changed egr front 2400-2800 up 20% to help smooth a little.
Fifth run https://app.box.com/s/tn64j3n9stjj761rxwtm with https://app.box.com/s/v3g0fogeiyvu8k1g47o4
ran vtune
Sixth run https://app.box.com/s/aqbdu2dn2l9g8rokw21z with https://app.box.com/s/e949iovu1wrfqi6fmk6c finally able to start filling all the cells
ran vtune, front spark 3000 up, 50 kpa up, 2 degrees down. rear spark 3000 up, 50 kpa up, 1.5 degrees down
Seventh run https://app.box.com/s/ksho36x7znt1culmhnro with https://app.box.com/s/4r7lbigs42s7djsfapc1
ran vtune. rear egr up 30% 0-1600. front egr up 20% 1600-2800
this is the map I am running right now https://app.box.com/s/qbzemanez6srvrribrxz
I don't have the hesitation I was getting, but below about 2700 rpms on a flat road you can feel some small misses here and there, just not real smooth yet.
ran vtune
ran vtune
