PowerVison Autotune Question
I posted a while back about decel popping and wasn't having any luck with autotune getting rid of it. I emailed FuelMoto and got a new tune which was working great. I contemplated just leaving things alone but after reading how autotune worked so well fine tuning things I decided to do a run today using it. When I got back home, I loaded the run into winpv and did a compare with the tune that fuelmoto sent me.
I am seeing as much as a 15 percent change in some of the cells!! Is this normal?
I do have winpv set to pro. and looking at VE only.
On a side note, after loading the new tune to my bike, it seemed to be smoother. At first I thought maybe sluggish so I intentionly slammed the throttle going through the gears and WOW!! Not sluggish at all. Just "smoother" if that makes any sense.
For info I have a 2013 Fatboy with the FuelMoto billet air cleaner and Rush 1 3/4" slip ons.
Thinking about RB Racing 2-1 exhaust or Vance and Hines Big Radius as an upgrade. Still researching the 2-1 thing over 2-2.
