Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Every time I put a load on the motor(rolling on the throttle to pass, or climbing a hill)the check engine light comes on. Once the load is gone the light goes back out.
Ive pulled the codes and found p261,p263 and b1004. The p codes are low or open fuel injectors. The b code is a fuel level sending unit low.
any help on the cause and repair would be appreciated.
Are you running SE spark plugs? We had this happen about 2 weeks ago on a bike in our shop. Same exact thing you are having. Changed his plugs to regular plug and wham, no more problems.
