new build tune question
Hey y'all, I just upgraded the 88 to the 98 and also the cams.... here is my issue, I have a close map, but I need to really richen the map up..... would it be easier to increase the ve tables across the board or lower the a/f ratios just till I can get to the smart tune
i have no experience with your tuner but with mine i would change the afr, tho it may not mean a whole lot if your ve table has changed a lot.
someone with more experience than me would be better to answer this, but until they do you may be better off adding to the ve table, leaving it in closed loop until you can properly tune it.
