Intermittent Shutdown
Was looking thru the forums but haven't found what I am experiencing. My bike will start fine usually and while riding it will die. The lights and electrical stay on but the bike does. I can sometime turn the ignition off/on and pop the clutch and away I go. But lately I have been noticing that I can't hear the fuel pump start. I'll turn the bike off/on several times and then all of a sudden the fuel pump kicks in and the bike will start. I can ride for undetermined time then it'll do it again. Any ideas guys?
Start with the fuses and fuel pump relay. The contacts can get a little corroded so you need to clean them. The fuel pump relay may also be going bad but this is something you can buy for a few bucks at an auto parts store.
Also check your connections at the battery and the ground cables.
Out of subject matter
My name is David Shultz and I'm a new member. My handle is Fairshake. I have been trying ways to contact Dozer 40 but the system will not allow it. He has a item for sale in the classifieds and I want to buy it.
The system will not even allow me to contact a moderator. I left my contact info on the classified ad. Thanks for any help I may receive. Later David
wes
04-18-2006 12:31 PM
