Looking for sert cables or equal
I contacted a seller on ebay and he said his cable kit is only for the TTS.
Do you know the part# so i can accurately order the cable kit?
Thanks, Dennis
2000014 J1850 4 PIN Cable Kit $42.50
http://www.mastertune.net/harleydavidson.htm
You have the old SERT. It is the J1850 ECM with the 4 pin cable.
You will also need the serial to USB cable.
2000006
USB to Serial Cable
$43.95
This came from the TTS site.
There is a KIT with both cables included. The price normally is about 70 bucks.
Call Alice tomorrow and tell her you need the older style black box cable kit for the TTS. She will know which one. Click here for her number -->> http://www.fullsac.com/
2000006
USB to Serial Cable
$43.95
All the info is there. I believe if your ECM is 2005 and up you can go through the SERT to TTS exchange. You will need to download a file and follow the directions. Send in a form and a copy of the file along with your SERT.
Remember, I don't work for nor am I associated with TTS or Mastertune in anyway so all this info should be discussed with them.
I also know if you have another bike (2 bikes total) and a single bike TTS you can send your TTS back to them for conversion to a Dual bike TTS for $200.
Just call Mastertune and get their specific instructions.
I see I priced the upgrade incorrectly.
http://www.mastertune.net/sert.htm
Upgrade your old HD SERT to a TTS MasterTune:
To see if your SERT qualifies for an upgrade, you must run the SERT upgrade utility and print the resulting report.
All SERT upgrades will require a RMA and a SERT Qualifier report.
To receive a RMA please email our office and a form will be emailed to you for completion.
Once you have completed the RMA form, print it out and return the RMA, Interface, and Qualifier report to TTS.
The unit will be here about 10 business days, and the charge is $100 + shipping charges
If you have any questions, please contact our office prior to sending your unit in for upgrade
Failing to follow the above steps will result in a delay in the upgrade process.
