1999 flhrci ecm 32423-99c help/info
I took my new FLHRCI to the HD dealership to to check if it is flashed for stage1 or not. Dealership says that is a non stock ECM and they can not read it. I did some research and found that this was shipped with a DC9 cable and some software called Pro Tune II . Anyone know where to get a copy of this sw and the pin out for the DB9 M?F cable?
Harley Davidson Electronic Control Module & ProTune II Software, OEM# 32423-99C
HF-DEP-DES-0906-c1 DB9 Cable
106-6220 pro tune software pro tune II 1.1 Disc
Kit is
32423-97c , 32423-99c , 32476-99b
Thanks for any help you can provide. Apologies if this is in the wrong area..
Rubber Side Down......
Kit is
