Sticks On Fast Idle
Sticks On Fast Idle
I have a 2007 Dyna. The problem is that when I wind it out in 2nd gear, the idle stays fast until I turn it off. Then, when I re-start it, the idle is normal. Checked for intake leaks. Throttle cables and IAC replaced w/o improvement. I've tried the on-off reprogramming method w/o success. Throttle shaft and throttle stop screw checked and ok. Next will be to replace the throttle position sensor. If you've solved this problem before what was the solution? Thanks.
Z_Stingray
05-27-2008 07:34 PM
