Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I recently had a detach kit put on my 04 Ultra. Today I wuz out riding and a fellow rider informed me that I had no brake lights. Someone suggested it wuz a fuse. But the only fuse is for Brake/Cruise. However the cruise light comes on when switched on. The other is a relay. Any info?????
Check the bulb! Try a replacement, even if it seems fine. If no joy, check the brake light switches and wiring to both. There could be a disconnected wire, broken or damaged wire.
