Where Does the Power Vision Save the Stock Tune on Your PC?
The title of the post pretty much lets you know what I'm asking-I just want to back up that stock tune on a flash drive as well as my laptop-when I hooked up the PV, WinPV asked me if I wanted to save a copy of the stock tune to my PC and I said yes- where did it place it? Thanks.
It will put it in the Power Vision directory under c:\program files\power vision. You can also GET the tune again and save it to any folder of your choosing. I setup a Power Vision folder in the Documents library so that I could track all my tunes and make them easier to find.
it saves your original tune to your documents folder under a folder named powervision . It will not be a power vision file . If you want to view it as a power vision file re flash the original tune to your bike and then get a copy of tune and name it original and then reflash the tune you are running now . When it saves original it saves more data than you can view and edit with power vision when you re flash original tune and copy tune you get only what power vision is designed to work with .
Hey! Neat and thanks for the question! I got my PV2 a couple days ago and have been messing around with it. I was worried that I didn't even have a stock backup for a while. I kept trying to open the stock tune and noticed it was names "copy of ORIGINAL TUNE.pvt". I didn't see a ".bak" file until I navigated to it, after reading this thread.
Also, I don't think I made a backup in the way it says on here: http://www.powercommander.com/downlo...3_3-2-2011.pdf
Anyways, I'm heading back to Google to figure out how to use and read all the details this thing puts out.
Thanks for the post!
