1999 dyna with no spark
Any help appreciated.
First is there a separate electrical troubleshooting manual?
I ordered the maintenance manual but shop I went to says there is a separate electrical manual.
I have power 12v to the centre coil wire, cranking I have no voltage to outer front/rear spark trigger wires.
Found a thread online that said what wire to check cam sensor and I have 5 volts ign on and 2.5-3.5 while cranking which I think is fine.
Crank sensor has 1.7 volts cranking.
Bas sensor seemed to be gone so it is jumpered as of now until I get a new one.
Any input very appreciated.
Thank you Rob
Thank you Rob
gerry_bc
02-25-2016 04:00 PM
