won't start
won't start
hi hows it going i have a question. i put new heads on my 2006 roadglide and now i have no spark , what could i have knocked loose, if the push rod were in the wrong spot could that cause it. does the fuel tank have to b pluged in to make a loop ? can i get spark by pulling the plugs and put the wires back on the plugs then ground them while rolling it over thanks larry
The push rods have nothing to do with the ignition, they do have everything to do with opening/closing the valves at the correct moment to get compression, at that point in the stroke ignition should occur. The 96 has a sensor (crank sensor) that is very important in determining where in the stroke the piston is. If this sensor is bad or can't be read you will get no spark. Take the plug out, ground it and crank the engine. No spark then remove the crank sensor, clean it and reinsert it.
Ryanwnklr
09-04-2018 02:48 PM
