Tuning advice
If you don't mind learning a little bit about the tuning process, the Power Vision is great. If you buy from Fuel Moto, they will send you the PV with a custom tune to match your set up and they will be available by phone or email to answer any questions you have. The PV is not a piggyback system, so you can leave it at home or mount it if you want to moniter some ECM info. You will be able to remap if you decide to change your set up later(like cams, new ac, etc). It also has an Autotune feature that will improve the already nice map that FM will send you. Bottom line, do a little homework - you will have a great fuel tuner and will never need to get a dyno.
Jgrasham
03-08-2015 11:47 AM
