Check engine light
Check engine light
I have a 2009 Electraglide Ultra Classic. Great bike, runs good. However, on a very occasional basis it goes to Check Engine and the bike goes into a governed low speed mode. I have checked fluids and can find no other reason. I read that the EFI monitors spark plug function so I replaced the plugs with the higher performance HD plugs and still have the problem. After I pull over I can turn the ignition off and on a few times and it will start and run fine. Any help would be appreciated as this could get ugly on a busy freeway or heavy traffic where 15 mph could be terminal. Thanks
Under what conditions does this happen? Check to see if the bike threw any codes. This should help:
https://www.hdforums.com/forum/elect...tic-codes.html
Wasscally Wabbit
06-03-2014 07:17 PM
