2003 vsrc ecm code problem, need help
Hello, can anyone help with the following code appeared?
U1016 Current Loss of all ECM serial data-at TSSM 3.19 DTC U1016
U1096 Current Loss of IM serial data-at TSSM 3.20 DTC U1096, U1255
Right now the fuel pump isn't pumping, can't fire up the engine. When push the RUN button, the ignition light doesn't come up.
What should I do? Anyone can give me a help here?
When these 2 codes appear at the same time it's usually indicative of a TSSM problem. Find your ECM and TSSM. Pull the connectors off of each, clean them out, check for corroded pins, put dielectric grease in the connectors and mate them back together. Reset your codes and see what it does.
masterblaster
03-19-2011 04:06 PM
