power commander III fuel tables ?
I've got a custom map and it is using two fuel tables and I can't for the life of me figure out which table represents cylinder 1. By the look of the extra fuel in table 1 I would assume that is the rear cylinder and the extra fuel would be for cooling purposes. Can't find any info on the interweeb, figured that would be a common question seeing as the software doesn't indicate which is which, unless most tuners put it in the notes, mine didnt? Anyone?
I don't know the answer to your question specifically but I would think (based on info I've read) the fuel tables do not mean what you think they mean. According to FuelMoto on a 6-speed bike there can be as many as 24 fuel tables in 1 map.
http://www.powercommander.com/powerc...l_support.aspx
I decided to send an email to Jamie at fuelmoto and on the PC III the number 1 table represents the rear cylinder.
