Brake light issue
Brake light issue
I just noticed the brake light on my '07 WG isn't working. I haven't had the bike very long, so I'm not sure if it was ever working. I switched bulbs and noticed both filaments are lit up even when the brake is off, so I'm guessing the brake light is actually stuck on. I switched out the switch housings for chrome ones last month when I changed out the handlebars, so I'm not sure if something is shorting out? Any ideas?
Thanks,
Matt
Thanks,
Matt
What he said. Tip broken off of switch. I'll bet the grips have been changed and the tip was broken off because the brake lever was not wedged clear of the switch per the manual.
In 08 (i believe) HD finally got their heads out of their asses and changed that brake light switch on the handlebars to one that did not have the "breakable" tit on it. Anything prior to that had the little tit on it that if you didn't depress in with a piece of cardboard or something similar while disassembly and re-assembly of your switch housing would snap off. There are many options aftermarket so you don't have to pay the ridiculous price of $50+ at HD for a new switch part # 71621-08 (new style)
