Help Identifying Electrical Component
I posted this in the touring forum but in hindsight it probably should have been here;
I purchased a 08 FLHTC back in July one of the first things I did was change out the stereo. When I pulled the outer fairing I noticed a few "components" that are not identified in my service manual. I've done some research but can not figure out what they are.
Its probably something simple but I hate not knowing. Its obvious they were added after it was purchased because of the way they are mounted and wired in. This is definitely not a factory or even a dealer install.
The one component had a serial number that I googled but found nothing.
Anyway here are some pics, Im hoping someone can help me out
The two components are installed here
The first has nothing on the top but has a little light on the front right that will blink occasionally when it is bumped which makes me think it may be some type of an alarm system but I do not have a key fob and never needed to do anything special to start the bike
Here is the bottom
It is wired into two places one seems to go into the main harness and the other to a relay
Here is the relay
Here is where the other wires go
The other component has no numbers or marking and has a single wire bundle coming out of it that disappears into the main wire bundle in the fairing
Any help figuring out what these things are and if they actually need to be there would be greatly appreciated.
Its obvious to me that whoever owned the bike before me had done some work on it as it had a load equalizer in it for a LED headlight and the fairing speakers had been upgraded. Unfortunately I purchased the bike form a dealer (Non HD) and have no way of contacting the original owner.
Thanks Again
Greg
Here is the bottom
Here is the relay
Thanks Again
Greg
based on the box itself being sealed and it lighting up when bumped, then the other black box being sealed with epoxy on the bottom of it, then the relay (4th picture), I would bet its an alarm system of some sorts.
Where does that grey wire go coming out of the box in the last pic? Can you untape that bundle where it goes it to see what it's tied into?
Where do the wires on the relay (4th pic) go?
Thanks for the reply
I was looking at it again today and it seems that movement does not cause it to blink it just blinks all the time. It has a red light that blinks at a pretty constant rate and then a green light above it that is more random. I tried tapping on it and moving it upside down and it did not seem to change the rate of blinking.
Im almost at the point of saying "If it aint broke don't fix it" as the bike runs fine, I just hate not knowing!
Im thinking your right, I may chase the wires a little more to see if I can remove it. The bike did not come with a key fob or anyhingto arm or disarm the alarm so it does not seem to be active if thats what it is
Thanks Again
Greg
Thanks Again
Greg
If you try to find out were the wires go, what color they have and to what color they connect at the harness, you might be able to draw a diagram and post it. Once we know what color wires of the harness are used to connect to, we might be able to find out what it's used for....
Toneaero
04-30-2023 04:29 PM
marshallb
Audio Systems
18
10-15-2017 02:43 PM
