Starting / Light Problems
I have a 95 Sportster 1200 that is having problems starting. The tach light and headlight (both low and high beams) will also not illuminate. All other lights work fine. When I try to start the bike it does not even crank or click. It just does nothing. The battery is good and I checked the fuses, but I am not sure how to tell if they are good or bad since they are not see through.
Is there anything other than fuses that would cause this combination of problems?
Any suggestions would be appreciated.
Thanks,
Craig
Thanks,
Craig
RE: Starting / Light Problems
I agree with John, main breaker, ignition switch or a wire off somewhere. You can also check it out with a 12 volt test light. Find your main breaker and test both sides of it with the light. It should light on both sides if it's good. From there go to the ignition switch. This is where you need the manual. You can test it to see if one of the terminals becomes energised when you turn the switch to on and de energised when it's off. Don't confuse the accesories circuit with the start circuit.
