turn signals dim with lights on
here is the problem i have a 1994 flstn and in the rear i put a 2002 road king rear light bar with the bullet lights. when i have the lights off turn signals work fine nice and bright but when the ignition switch is turned to lights and turn signal button pressed the turn signal light is very dim and cant tell if its blinking. any help would be great thanks
If they are LED signals, you might need a load equalizer installed. See link:http://www.badlandsmotorcycleproduct...OULD-I-USE.htm
NCCopBikeRider
01-25-2009 02:07 PM
