Tmax without factory alarm ?? Questions... (possible or not ?)
Hello,
first sorry for my English but I speak french usually.
I have a question
I'm building a bike from scratch, with an engine/gearbox from a 2007 Dyna.
I had with the electric harness but not the ignition module (EFI) and not the factory alarm (turn signal & security module).
Then I want to put a Thundermax on this bike, but I do not know if it will work alone without the stock alarm system (alarm that I did not).
I studied the wiring diagram and there is a connection between the alarm and the EFI, "VSS Serial data link", (I am electronics engineer and I have no problem with electric wire, I can simplify the harness to remove the unnecessary wires ), but I don't know what transmits this wire.
I think it could also be a problem with the "bank angle sensor", I think this one is in the security module ??
So.... did someone can help me ??
Thank you in advance from Belgium
I have a question
