Need Help Fuel Injection
Old 10-23-2012, 08:54 AM
roadking238's Avatar
roadking238
roadking238 is offline
Stage II
Default Need Help Fuel Injection
I have 2001 Road King with a magnett marelli fuel injection. I have owned the bike only a few months and i am having nothing but problem with the fuel system in this bike. i have already replaced all fuel lines and fuel pump. the other day i was riding and the bike engine just died out. did the checks got spark and i have fuel going to the injection but the bike is not starting. when i spray starter fluid into the intake the bike fires up like nothing to it.but wont stay running. leaves me to believe its a fuel problem. any help and advice would be great. parts to way to expensive to go replacing one after another. please help
Old 10-23-2012, 10:23 AM
custommade48's Avatar
custommade48
custommade48 is offline
2nd Gear
We are having a similar problem with a 2001 Road King , hard to start sometimes .
I'm sure it has the same injection system . Looking for a solution as well .
Old 10-24-2012, 01:57 AM
rickss69's Avatar
rickss69
rickss69 is offline
First order of business for both of you would be to check trouble codes. You would need at the minimum a Diagnostic Test Lamp (HD-41197). When you first turn the ignition switch on the check engine light should illuminate for around 4 seconds, then go out. If there is a functional error the check engine light will illuminate as before for 4 seconds, go out, then illuminate again for about 8 seconds. If a current trouble code exists the light will remain on as long as the ignition is energized. You really need a service manual's aid for troubleshooting these systems.
Old 10-24-2012, 07:19 AM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
have either of you checked your CPS (crank position sensor)? could be dirty or needing to be replaced.
Old 10-24-2012, 11:20 AM
custommade48
2nd Gear
We are taking it to a Harley mechanic this week , I'll let you know what we find .
Thanks for the input. UltraNutz & rickss69
Old 10-24-2012, 02:19 PM
No Name Motorcycle Shop's Avatar
No Name Motorcycle Shop is offline
We just had a 2000 FLHRI in our shop as it would not start. Customer brought it in saying he thought it was the fuel pump. But it was the ECM. The Control Module was not allowing the fuel pump to fully prime.
BTW the Marelli setup was not a very good one. They inherently have lots of problems. We recommend to our customers that want to keep the bike to perform a Delphi Conversion by replacing the throttle body and ECM offered by Zippers Performance.
Old 10-24-2012, 02:24 PM
UltraNutZ's Avatar
UltraNutZ
good information to store in the few brain cells I have left... thanks...
Old 10-30-2012, 12:20 PM
custommade48
2nd Gear
We found the problem with the hard starting Road King , it was the throttle body , it was all gummed up and the air filter was dirty .
Purrs like a kitten now .
Thanks for the help guys .
Old 10-30-2012, 12:26 PM
UltraNutZ's Avatar
UltraNutZ
always the simple things that get you! :-) glad you got it sorted out
Old 11-01-2012, 09:58 AM
roadking238
Stage II
Thanks for all the help. I will start going though the list. thanks again.
Quick Reply: Need Help Fuel Injection
