Another PCIII question
Mac,
So when you are looking at the grid in the software...Assuming you are using the software loaded on a computer.
Every number you see is a percentage above stock of fuel. So you can set 10% richer at 20% throttle and 3000 rpm for example.
It's not like a carb where you can just richen it up a little. You have much more control, which equates to much more confusion... at least for me![Big Grin](https://www.hdforums.com/forum/images/smilies/biggrin.gif)
So anyhow, pick your rpm ranges and your throttle percentages and up the numbers as you desire. You can also use negatives to lean it out some over stock.
Don't forget to zero the throttle when you install it, otherwise the whole map will be 'off'
Page 2 of the map allows you to do the same but advancing/retarding timing instead.
Does that help?
Does that help?
ORIGINAL: Rhubarb
Mac,
Does that help?
Mac,
Does that help?
When I spoke to PC tech support he said to be sure to set 100% throttle as well as 0%, something that is often overlooked, which can be achieved by clicking on the appropirate button and blipping the throttle quickly to WOT. I hadn't and it was off, but now corrected.
BTW, how did you make out with your tuning we discussed about two months ago? I keep leaning out the take-off and cruise regions of the grid and am down to 2 between 2000-3000 rpms and 5-10%, and have also decreased 1000-2000 @ 0-10% throttle, neither with any ill effects. Once in a blue moon it will burp slightly right off idle, but it is rare and hardly noticeable, and I've seen no heat problem or detonation yet. Oil temp stays <200°, usually 150-180° while rolling in these cool temps. Have a cooler but it should not be kicking in at these temps.
Face Plate Buttons
You can change the fuel curve with the faceplate buttons. This is a simple adjustment that can move the fuel curve richer or leaner in each area of the map.
1. Press all three faceplate buttions at once
2. Turn on ignition
3. Set the desired degree of richer or leaner mixture using the buttons in the desired rpm range
4. Turn off ignition
The exactinstructions are in the documentation that came with your unit or may be viewed from the CD.
Good luck
2. Turn on ignition
Good luck
I have to admit that I am chicken. Because I don't have the tools to monitor the EGT and mixture, I'm afraid I will lean it out too much and burn a hole.
I find it pretty amusing that I am scared since I wouldn't hesitate to tune a carb.
I flipflop every week on getting a professional tune for $375.
Your results sound great... How is the fuel mileage doing?
ORIGINAL: Rhubarb
Showoff ![Big Grin](https://www.hdforums.com/forum/images/smilies/biggrin.gif)
I have stock 88 with pipes, ac and PCIII and get a whopping 35...
Iclick was doing some experimenting with timing and cruise values...
ORIGINAL: Tripper
I have a 114cui kit installed with a PC III and I get between 38 and 41 mpg.
Be sure to check the plugs while your testing so you don't run her to lean and ruin the engine.
ORIGINAL: Rhubarb
I'm getting about 36-38 mostly around town in these cool temperatures when there are lots of cold starts. It takes this engine forever to warm up, as related to oil temperature, and while it is doing so the EFI is compensating by dumping more gas into the mixture. Frankly, I don't think there's anything that can be done about that short of finding a way to fool the EFI into thinking the bike is warmed up. Then I would have to endure the behavior I experienced with my carbed Evo when I pushed the choke in one block from my house, sputtering and coughing, in the interest of better mileage.
On long rides along the backroads I've been getting 46-48, higher as the air temps increase. I think mileage will go up 10% or more in summer, and if I can get 40 in town and 50 on the backroads, I'll be happy. I think it can do it.
iClick,
I failed... I have scheduled an appointment with a well respected dyno house for Saturday.
My bike has spit and stalled on me 2x now, and i just want it done with.
I will post the map, they said they will make it as fuel efficient as possible. They also said that doesn't mean they will cut power.
We shall see what happens. They are going to let me sit with the guy the whole time and discuss things with him.
I'm going to ask about adjusting the timing as you are doing. I have written lots of notes from your posts.
Thanks for all the help. I wish I wasn't so chicken, but she's my baby[&:]
