True Duals and S.E. Tuner
is it true duals or stock head pipe 2-1-2 with slips ons?
either way i would retune it. Would be more inclined to tune it if it were true duals because of the loss of back pressure and a more "free-flowing" exhaust in a true dual setup. Most folks who put on true duals wind up compensating for the loss of HP and TQ by adding a set of good cams. Just my .02 worth. As for tuning, open up the software, find a map that closely resembles your engine build and modifications, and smart tune it. Smart Tune only works with certain versions of the tuners. If you have the SERT or the SEPST then you can smart tune, otherwise you'll need to find a local tuner to help you out.
blusmbl
12-09-2011 09:29 PM
