burning out front signal/marker lights
Old 08-20-2012 | 06:38 PM
jlasoftail's Avatar
jlasoftail
Default burning out front signal/marker lights
The front signal/marker lights seem to be going on me nearly every week. Always seems to be the marker filament, not the flashing one. I did a voltage check with bike off, bike starting, bike idling, and bike reving and all voltage seems normal. Never ran over 13.5V and never spiked up or down. Any ideas where to start looking? All other lights seem fine, but I did have to replace a driving light a month ago, although at 50k km I wouldn't say that would be unusual. Bike is a '09 FLSTC.
Old 08-18-2013 | 04:17 PM
rtonerii's Avatar
rtonerii
Stage III
I just saw this post, I am having the same problem. What were you able to do to fix this issue?
Old 08-19-2013 | 07:47 AM
grbrown's Avatar
grbrown
That was a year ago, so we don't have much chance of finding out! Most likely problems are a damaged wire going to ground, or poor electrical connections. Do a thorough visual inspection of wiring to those lights for dirty, poor or loose connectors.
Old 08-19-2013 | 09:15 AM
rtonerii's Avatar
rtonerii
Stage III
Thanks Graham,
One other thing that might be causing it, I recently went to the Custom Dynamics rear turn signal lights. Not sure but since they are LED and the front ones are standard, I was thinking that might be causing it, different voltage loads.
Old 08-19-2013 | 09:51 AM
grbrown's Avatar
grbrown
That is possible. I have LED indicators all round plus a ballast to compensate for the flasher unit. It might be worth swapping the rears back, if that is easy, to see if the fronts are cured. Or replace the fronts with LEDs as well!
Old 08-19-2013 | 10:39 AM
rtonerii's Avatar
rtonerii
Stage III
I think I am going to just od LED upfront and a stabilizer.
Andrew Buckley
Electrical/Lighting/Alarm
12-26-2019 10:03 AM
nthere1
05-14-2014 04:38 PM
johnnyocc
10-25-2011 06:03 PM
charliebravo
03-03-2008 03:44 PM
jopeck11
General Topics/Tech Tips
07-13-2007 07:58 PM
Quick Reply: burning out front signal/marker lights
