Blowing ECM Fuse, Only Running on One Cylinder..Any help will be appreciated.
I was riding my 2012 Iron 883 the other day and It had been sprinkling a little bit. Started out running fine then died going down the road. It blew ECM fuse. found out it was a ex[posed wire from handlebar internal project. fixed that and now im only running on one cylinder. no spark from one side of the coil pack. and check engine light is on. if any ione can help please let me know. By the way. there is a recall about a voltage regulator on my bike could this be the problem?
nz3204
11-15-2007 02:39 PM
