Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I have a 1986 wide glide with the stock junk carb it fires right up but the the more throttle i give it as i shift it seems like the the choke is on or its running out of gas. And the plugs are always black when i take'm out,Clean them ride for a mile and there black again Im think'n new coil or something carb. Thanks for any help
Hey man. I by no means have a solution for you. More of a question... Since I'm mechanically challenged. How do you clean your spark plugs? I thought once they were fouled they were done for.
1) Check for spark; if ok, then look at carb
2) Carb; take it apart see if your float is stuck or just plain broke (cracked) and filling up with raw gas.
Had the carb rebuilt at a bike shop put new plugs in runs good for 6 or 7 miles then falls on its face pull the plugs and clean'm then runs fine again then does it again. Try'n a new coil next. If that dont work gona try a bullet
