Rear Lights
I was thinking along those lines, but tail light was flickering on the initial ride home and brake lights were working fine, according to the person that gave me a ride to buy it. As time went on and now in the garage, no taillights at all and brake light only worked with key in the acc position. I flipped through the wire diag. and thought about it for awhile. I knew it could not be a fuse but went out and checked them anyway. Then I followed the rear light harness from the light to the connection under the seat. I found when I moved some wires everything worked. I narrowed it down to two possible wires at the end of the connector. I pulled connector apart and just slightly bent both prongs and now all is well. Thanks, Chip
